my "Winston Cup" 69 chevelle project
#131
The bullet has arrived. 680hp 434 Dart Iron Eagle block, Callies crank, Crower shaft rockers, solid roller, Jesel belt drive .736 lift. 15 deg Nascar "Pontiac" heads. These were from back when Pontiacs and Buicks ran in Cup. Ive you had a chevy the heads say nothing, if you ran a Buick they would say Buick, ran Pontiac said Pontiac but were all the same chevy head. The SB2 replaced this engine. The clincher was 11.3:1 pump gas. Thing dynoed at 700 even with a 1050 Dominator ran a 3300 Iroc 9.40s last Sept shifting at 6800 off a brake. Estimate 680hp with a good 750dp. I'll change the pan to the Canton shown in the pic but will piece together a dry sump eventually. Bills show complete refresh last June , guy said 15 to 20 passes since. Should haul like a mofo I had to have it.
#134
Found out the pan in the above pic wouldnt work as the Dart block is a "spread rail" design in the pan mating surfaces to accomodate the stroker crank. It also has the cam galley raised up in the block for the same reason. So I ended up having to get a special order roadrace wet sump pan from Moroso. And the headers were special order from Schoenfeld in Alabama. But theyre here now and after I get the trans back I can mount it and start plumbing/wiring the actual engine Im going to use instead of the mock up engine. Hours and hours on the web/phone sourcing those parts as neither of them are listed in their catalouges.
#135
SORE MEMBER
1 Post
![Drink](/forums/images/smilies/drink.gif)
#136
In one way its easy because its so out there I can do anything I want, on the other hand its hard because I can do anything I want..... there are 10 different solutions to everything that needs to be done. Makes your head spin. If you are restoring a car back to bone stock its much simpler (I didnt say easy) because you look at pics/books etc and put it right back to stock. You know exactly where you have to go.
#137
After buying the battery box off a picture in a catalog and obsessing over placement I put it here and Im happy with it. Kind of central but over to the right to offset driver weight, protected and can still get the fuel cell out. And still room for a dry sump tank to the right.
#138
In the previous pics the glass bumpers were just sitting there balanced on the car. After more head scratching I came up with this bumper/mount. Same done to the rear.
#140
Spoke to David from Va at length about the rear spoiler. He said "Six inches tall and 60 degree angle" I said Holy Sh it thats big! He said "You have to pin that rear end down solid or it will be so dog gone loose you wont be able to drive it".....OK fine thats what we'll do. Heres a mock up. Thats 6.75" so it will be a little shorter. And a pic of the one that came on it.
