Fuel Mileage when towing??
Old 03-04-2008, 09:21 PM
exmark31's Avatar
05 dodge ram 3500 2wd
21 interstate
18 in town
13.5-14 pulling 31 sonic
factory stock
exmark31 is offline
Old 03-04-2008, 09:27 PM
Smitty's Avatar
2003 F-350 4X4
6.0 Powerstroke with exhaust and tune
pulling 15K
I get 9.0 to 9.5
Smitty is offline
Old 03-04-2008, 10:01 PM
Full Force's Avatar
99 F250 7.3 with chip... summer 15-17 empty average, 15 towing cars, 11-13 towing boat 32 Baja depends on speeds.
I look at it this way, towing a bigger boat... if you get over 10 you are doing good !!!!
Full Force is offline
Old 03-04-2008, 10:42 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Is it wrong to complain about getting 7mpg in a truck while towing a boat that might get 1 1/2 mpg at best?
US1 Fountain is offline
Old 03-05-2008, 01:55 AM
handreasen's Avatar
Originally Posted by baywatch
2005 Dodge 3500 Srw gets 13ish pulling the boat. More like 18 without load. I tow around 65-67 mph, don't let her go over 70 unless I am gaining momentum for a big hill or something.
If you had a DMAX you would not have to worry about momentum.
handreasen is offline
Old 03-05-2008, 05:14 AM
Full Force's Avatar
I am a Ford guy but do have to say Dmax and powerstroke have nothing on a Cummins....too bad it has a dodge body around it!
Old 03-05-2008, 06:53 AM
Location: A tree somewhere in the woods in Clarcona Fl.
06 Ford F350 4x4 dually 6.0 crew cab automatic with tow boss pkg(4.30 gears) Edge programmer set on 2, Bassanni 4" turbo back system and an Airaid airbox/filter. Also went to 19.5 rims with 265/70r19.5 Michelins 14 ply's(34.5 tall)to help compensate for the 4.30 gears
11.6 around town(commuter)
17.3 highway(at 75 to 78 mph)
11.2 towing(app 12,000 lbs)
Slick02 is offline
Old 03-05-2008, 08:42 AM
Forum Regulator
Sydwayz's Avatar
Received 1,249 Likes on 542 Posts
I spent a little time pulling with a new 6.4L PSD last month in Florida. When I figured out that I could count the MPG on one hand towing 12,000 lbs.; I just gave up on the actual number.
I did like the truck though, but I love my 2000 7.3 PSD. I have a DRW CC and get 8-9 MPG towing 12K lbs. +/-.
A LOT of things like tire size, wheel size, overall weight, speed, gear ratio, SRW/DRW, 2WD/4WD, camper shell, and frontal surface area of what you are towing varies MPG by as much as 5-10 MPG.
Attached Thumbnails Fuel Mileage when towing??-jammin-james-2007-096-medium-.jpg
Sydwayz is offline
Old 03-05-2008, 09:35 AM
Ouch LOL !!! I would still carry speed into the hills even If I was pulling w/a Dmax. The power on the dodge is excellent, I just don't see the point on giving a bunch of brake (with in reason of course) when going down a hill when I have 400 yds of flat and then go back up another hill. I just let her coast down and carry that momentum into the next one and that is when my speedo might run over the the 70mph mark.
I have always had Chevy's. My old 95 blazer has over 200k miles and is still going strong as a daily driver. The dodge was about 8k cheaper and that in the end weighed in heavily.
baywatch is offline
Old 03-05-2008, 09:43 AM
2007 Dodge 2500 4x4/ 6.7 Cummings Diesel
Average including highway 17-18 mpg.
Towing, 42 Fountain -- average 10-11 mpg.
I like the jake brake setup for slowing everything down. Works very well with electric over hydraulic brakes.
gerritm is offline
Quick Reply: Fuel Mileage when towing??
