4x2 Truck, how big of boat do you pull? Truck size, boat size?
Ever try to pull a boat up a ramp in the middle of a good rain shower????? I have, get the 4wd. If you do get a 2wd truck I'd recommend something that has a limited slip rear differential, like the chevy's. Almost like positrack.
SORE MEMBER
1 Post
I never have to use 4x4 on my local fresh water ramps regardless of the angle or the boat I am launching, but learned a valuable lesson that day. My truck will always be in 4x4 on any ramp from now on.
Now that looks like a F450. Seriously just playin around..I tow with a 08 F350 with the F450 front end. BTW nice looking Hustler..If that's the same one that National Marine had, I almost bought that in 2005..Just didnt trust Bill...It had trip 500 efi's if I remember correctly.
I have a 2007 Nissan Titan 2WD and I tow My 2003 30' Motion. I have used it to tow many boats and I am very impressed with it. I did install rear air bags with an onboard compressors. Knock on wood, I have yet to be stuck at the ramp.
Hope this helps.
Hope this helps.
Man some of the ramps down here, I've been to and I'm like what f'n moron built the ramp this way, like it was so hard to level the angle a little more, so many ramps down here will bottom out trailers.
You need to get that floating condo over this way and do some of the Lousianna runs..Tic Faw, Royal Purple and coming up is the Patriot run..and then dont forget the Emerald Coast run in destin..One of my favorites. Think you can make any of the two coming up..Thanks Jeff
