balance trailer tires?
six new skins going on my trailer
I can see nothing but positives for smooth ride and tire life, but 9 out of 10 say it's not neccesary.
opinions?
opinions?
I think it depends on how much you are going to use the trailer. If just for short trips several times a year not necessary.
If you are doing some long road trips it is absolutely necessary for tire longitvity and it does make a difference in ride!
LOL, believe me. It does make a difference in the tow vehicle as well! Most trailer tires that are used enough before dryrot sets in IMO are replaced because of the uneven wear patterns that develope due to improper tire balancing.(also the classic flat spots that occur if one has been locked down )
I had a contract when I was in the trucking business delivering HS yearbooks. Brought a trailer load of books from the factory and used a duellie and a trailer to deliver to the schools. Night and day difference in ride quality once I decided to balance the trailer tires!
Lakeside Restorations.com
Commercial Member
Technically not neccessary to balance the trailer tires, however it will only be better on the trailer & cause less wear & tear to have them balanced. It just is not a safety issue.. Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Why would anyone NOT balance the tires ?? It makes the tires last longer, makes the trailer bearings and suspension last longer and probably lessens the chance of a blow out due to excess heat.
believe me...I'm all about it,
but my long long time buddy and lifetime large local tire shop owner jumps up and down "it's not neccessary!"
they are all loaded in my snow trailer and are going first thing in the am to get mounted and BALANCED.
Thanks guys for backing up my thinking.
