switch from surge to elec over hyd...difficult and expensive?
ok, how much would it run to convert my myco surge to elec over hydraulic...and I have an 01 GMC dually, what would i have to do to the truck? already have controller from factory and 7 plug set up.
Do you currently have disc brakes on your trailer? If so you'll need an actuator (approx. $560 ) and a 2 battery breakaway kit (approx. $75) plus some misc. hardware for wiring and mounting the above parts. I was able to re-use all my existing brake lines on my trailer. I had drums and converted to Kodiak discs ( 3500 lb. axles ) for another $660, your larger axles would be slightly higher if you need the discs. You'll also want to gut the surge coupler and bolt or weld it solid. Hope that helps! Steve
Most controllers work with the electric over hydraulic. What ever it costs it's worth it. You'll never want to drive with surge brakes again. I would weld the coupler not drill and bolt it. Much more solid.
Ginger or Mary Ann?
Difficulty...... depends on your abilites.
My cost:
Brakerite pump: $560
Break away battery,box, switch and trailer pigtail: $75
Welder cost: $180 (I made several other improvements running this cost up)
Painting: $220
MaxBrake controller: $350
All the labor and steel fabrication was done by me.
Welding and painting was done by the pros.![Smilie](/forums/images/smilies/smile.gif)
http://www.offshoreonly.com/forums/s...d.php?t=196387
My cost:
Painting: $220
I just converted my trailer this summer. Myco uses the Brake Rite II system with a single battery. You will want to use their kit vs. purchasing it directly because they use a longer harness and can sell you the braket to mount everything to your trailer. Call Tim at Myco and he can set you up with the parts - they have outstanding service. Tim also send me a replacement tongue that slips into the frame so you can ditch the surge system. My first gen Prodigy controlled the system perfectly.
cbeastwood
3
06-30-2007 04:39 PM
BAD-HABIT
5
02-23-2004 05:18 PM
