Towing with a Hummer H2
#31
I dont get it. This post should be the Hummer is a great tow vehicle as long as you do not encounter a hill. Also the thing is stupid on fuel. The 1500's with 2 snowmobiles go 240 miles easy on one 24 gallon tank of fuel. The hummer takes two full tanks of fuel at 32 gallons. I told my buddy you want to take your Hummer good luck to you! Thaty truck is a joke. Yeah maybe GM made changes. This 2003 is garbage.
![Lolhit](/forums/images/smilies/more/lolhit.gif)
#34
#35
I love my 07 H2! It is the most comfortable vehicle I have ever driven. And it is a deceivingly smooth ride. But hook something on the hitch and the power goes kaput! I towed an enclosed single axle trailer with a couch in it recently and had to have my foot in it the whole way. But by itself, I love it. The loooong suspension travel makes it less tow worthy. T
#36
I live in Burlington, Ky. Some friends have H2s.... I have a Crown225 LPX and tow with a '04 Z71 Tahoe to Cumberland all the time.
In part, you're going to make the same trips I do. Take 75s all the way down to whatever exit (62) and for that tow vehicle, your hardest hill is going over fishing creek.
As stated prior, stay away from Jamestown
. I'd check out Alligator 1. The Army Corps have done an amazing job on that ramp. Alligator 2 is a nightmare and most powerboats shut it down and radio with CBs when they come down.
Scale yourself off 71 down towards verona if you're worried about it. Stay legal and stay safe. BUUUTTTTTT...... Russell is a dry county so you have to stock up somewhere
![Smilie](/forums/images/smilies/smile.gif)
#37
I believe the H2 came with 2 different gear ratios. 4.56 or 4.10. The 4.56 gears would tow better being the lower ratio. Also, the factory tires are 315/70-17 BFG All Terrains with a D load rating which is fine for towing its weight limit. However, towing over the vehicles limit is never a good idea.
#38
#39
We have an 03 h2 also that we pull our 28 foot velocity with. Braking is no problem, but power sucked. The damn things barely pull them selfs. I installed a magnasum supercharger "think that's how you spell it" any way what a defference that made. Now the only thing I have to watch is the temp gauges. Seems like the radiator is to small now. Hope this helps.
#40
I can say this, I went down the road of "Well, this vehicle should be sufficient to tow my rig. I'm only a little over my tow rating." That evaporated quickly when a woman decided she really needed to get to the mall and cut over in front of me and jammed on the brakes. I quickly purchased my first dually (Chevy gas burner) and progressed to my current F450. I can let my wife tow this thing now and not worry a bit about power, braking or a potential law suit.
Just my .02.
