F-150 Towing Capacity
Member #154
If you only do it a few times a year for local jaunts it's just dice rolling. Regarding the OP pulling a boat a couple thousand miles is just looking for trouble.
I did not calculate the breastssssssessess in there, if they'll be present then just ignore all the above and purchase a Freightliner
Forum Regulator
around town to a gas station o-k but not to Fla. I know from experience i have a 35 lightning and i am using an f-150 to move it around locally, would not even think about going out on and interstate with it on a long run. Looking for an F-250 diesel right now.
The bottom line is if the truck, trailer, and hitch are rated to pull the weight, your fine. This assumes you have proper setup and knowledge of how to tow. I see my fare share of idiots with very capable trucks 3/4 ton and 1 ton rigs pulling too fast, trailing to close behind others, and doing stupid things. No matter what rig you have if your set-up sucks, and you are foolish with your driving, its not safe. If its rated for it, your good.
