Road King Aluminum Trailers
Performance Boat Center
FYI, Myco just came out with a new, less expensive line of trailers... Be sure to call them before buying something else.
Also look at Continental and Float On.
Many of the others are very bad...
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim Gallagher
[email protected]
954-809-8739
I purchased a triple axle Float-On and after using it about 5 times, a wheel fell off in the ramp. The spindle fell off of the axle because of a bad weld. I was able to easily knock off the leaf spring mounts with a hammer because those welds were bad as well. When I got the trailer, every bolt was loose, nothing fit the boat and the fenders were junk. Overall, I think you can get by with an I beam trailer, but make sure you get good quality axles and tires with plenty of extra capacity. I think that's where some manufacturers skimp to save some money.
And thanks to all for the other comments. Keep them comming!
I had one Road King trailer under one of my boats when I bought it. Trailer was ok ... not good, not bad. It had torsion axles and Tie-Down surge disc brakes. The Tie-Down brakes were an absolute joke! They were nothing but junk! I changed out the Tie-Down garbage with Kodiak cad plated (or e-coat ... I don't remember anymore) calipers, caliper holders and rotors. Much, much better parts, IMO. You can do a search for "Tie Down" brakes on here and see others opinions, too. After changing the brakes, I made a couple of long trips (~ 500 miles, each) with the trailer and had no problems .... now that I think about it, I think I had to change out the tail lights, too.
I have a I beam trailer that came with Tie Down torshions. After the 2nd torsion failure and crappy non existant customer service I changed all three axles to dexter. Wow that was fun! Tie down products are throw away.
Is there a way to tell what kind of torsion's are used. If it has Tie Down brakes does that mean it has Tie Down torsion's? I know that Road King does use Tie Down brakes but I was planning on upgrading to Kodiaks.
