Manning trailer paint code
boatme says when he owned it?
My guess is your trailer is under a Sunsation
We did alot of trailers back in the day for Joe when I owned Manning The purple was a Kustom color to match the boat purple paint. What is under the purple paint it is a light grey primer then the color is sprayed then the clear coat is added to the process (was very expensive to paint ) Later on we found a paint that was close to the same color with out the 3 step process (Only two step)
You can touch it up with original paint just takes a bit of talent and a bit of build up
They said they do not keep records of paint codes/ build sheets of trailers they build.My Buddy is haveing trouble with his Manning trailer.
