hard to start diesel
1 Post
fixx
you need to pulll the intake to do a pmd unless you go with a fsd pdm cooler and extension harness....if the truck was dieing while driving then i would replace the pmd and resister.
bad batteries probably. Otherwise turn it until glow plugs go out, turn off turn back on then and do glow plugs again. In the cold these older diesels can take a while to start, although it shouldnt be to cold there.
Its eay to run ot out of oil when it leaks and no one looks at it. This truck gets the jump in and go deal.
Some more things i noticed today. When it is full throttle it sputters a little before shifting. Almost like a rev limiter. Another thing is once it starts it sputters for a second before running smoth. This truck would normally start up and run great all the time. I just got in it yesterday and notice all these little things. Its going in the shop next week unless it stops running. Its kept inside and starts funny hot or cold.
1 Post
fixx
first make sure their are no fuel leaks on the ground before starting in the am..
i forgot to mention,their is also a fuel heater in the filter housing that may need to be looked at,when the engine is first started wait a few minutes,,on the back side of the fuel filter housing is the heater element,,touch it and see if it feels warm...
and another thing i forgot to mention....thease 6.5's are known for cracked cylinder heads,they will leak antifreeze in the cylinders over night,,make sure the antifreeze resivour is full and their are no external leaks...a sign for leaking heads is hard starting and bellows of white smoke when first started..
Ill check but im pretty sure there is no fuel leaks. i dont think there was much smoke if there was it was white. Ill let you know when we get it fixed.
1 Post
fixx
when starting,,,white smoke is antifreeze,,lite greyish smoke is unburner diesel,,,it will have a strong diesel smell if diesel,, the smoke will smell like sweet diesel if its antifreeze
My choice is the new ford.
Ill see whats up with the truck so time after the holidays. Ill post anything i find. I got my truck back so out with the 95 chevy.
Have a good christmas everyone
