hard to start diesel
I just picked up one of my companys trucks and it is a diesel that seems to be hard to start. The truck is a 1995 chevy 3500 dually diesel. It is beat as everyone drives it and it gets no maintinece. Only as needed. I have driven it before and it started easyier than now. It is kept inside. Normally you turn the key till the glow light goes out and it starts right up. Now you turn the key till the glow light goes out and it cranks a while and tries to fire. I repeat the procedure and it takes a little cranking and will finally start. Any ideas. could it be a simple fix or it will go to the shop.
1 Post
im am a pro on the 6.5 diesel...first make sure the glow plug timer and glow plug light stays on for the first 10-15 seconds,,if it goes on then off after 2 secondw then you have some bad glow plugs,,replace them with wellin instant glows or bosch short fire glow plugs,,thease work way etter then the stock a/c glow plugs...
also make sure your batterys are in the best condition,thease old mechanical injection pumps need to see x amount of rpm in order to build up pressure in the mechanical pump to fire the injectors,,if you still have 15w40 in the engine and its below 32* the engine will crank over slow and will put a big strain on the starter,you need to drop the weight to straight 30w oil which gm reccomends for colder weather on the 6.5...pluging in the block heater also helps in the cold weather..
injection pump timing also plays a big part in cold weather starting on the 6.5,if their was a recent injection pump installed and the installer did not time the pump rite it will start and die,start and die..
if you plan on pulling with this truck in the summer heat their are a few cooling system updates that i can reccomend along with some mods that will let you hang close with a stock duramax..
![Drink](/forums/images/smilies/drink.gif)
The glow light did come on and off faster than normal a few times. This truck is abused. The motor was replaced in 2002 i think. A son of the boss ran it out of oil and ceased it. Its a shame. I have to say it run and runs and runs. One guy put gas in it. I know we had to have it all drained and flushed. That was about 4 yrs ago. The batterys are new and the starter is spinning very good so cranking and voltage is not a problem Its either fuel or the glow plugs i would think. I will fix it if it is a quick fix and cheap, other than that the boss can buy parts and ill fix on works time or send it out. Its like pulling teeth to get regular maintince done on our vehicles and we have a good amount of equipment. Sucks.
1 Post
![EEK!](/forums/images/smilies/eek.gif)
I would check the power driver module, a place in buffalo NY I think its called S&S diesel. My 1997 6.5 would barely run changed that which only took 3 min. to change runs perfect now.
It runs fine. It just cranks longer than normal. This thing normally starts like any fuel injected car. pretty quick to start. Ill check it out if i get some time tommorow. If it should not start in the morning than ill have to look int it.
A little basic maintinece goes a long way. Why dont people understand this.
ROCK ON !!!!!!!!!!!!!!!!!!!
![Coolcowboy](/forums/images/smilies/more/coolcowboy.gif)
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!
HAPPY HOLIDAYS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
![Big Bird Sesame Street](/forums/images/smilies/more/big_bird_sesame_street.gif)
