So, This Happened Today
Forum Regulator
But they cut corners everywhere! Look how far inside the axle the trailer I-beam is mounted, allowing a lot of flex of the exterior axle. They cut more corners than a first year woodshop teacher; meager-engineering vs. over-engineering.
instigator
actually the frame rails with the bunks on top of them are exactly under the flat of the strakes, where they should be... but you have a valid point that the overall axle width could have been narrower to decrease that *gap* due to the narrower rails... length is fine, beam thickness is fine, overhang is fine..
at least it's not 2_foot_too_short, like most of them down here are built
i would put three new 6lug, or 8lug type axles under it, cheaper than a new one, i would think what caused that was alot of tight turning twisting the axles.
Forum Regulator
This looks like it was one of the first low low budget Rocket trailer builds. They decided to delete the large vertical wood bunks and started mounting thinner wood bunks to the tops of the frame rails. I can see this being better for support. However, this trailer appears to be BEFORE they started going to narrower axles which actually put the fenders almost completely under the hull.
Many, many Sonics were delivered on Rocket trailers, especially in the Mid-Atlantic. This goes back to a strong alliance that Jay had with Armando at Rocket way back in the day.
My Sonic had a Rocket under it. I speak from experience. That trailer was terrible.
Ginger or Mary Ann?
My 1st thought too. Those tri axles really like to twist up when turning. Someone ought to make the 3rd axle a floater, for lack of the correct name. Wheels turn instead of scuffing.
Be thankful is was the last axle and not the 1st!
Thinking back, I believe I know what started this. In early August, I was coming back from Michigan through Wisconsin on Hwy 29. It's an odd highway in that there are crossing roads. Someone had spilled chunks of concrete all the way across both lanes. I saw it as I was passing a semi and had nowhere to go but over it. The trailer bounced up a bit. I stopped and inspected everything which all looked good, But, I bet this caused stress that led to the welds breaking.
Forum Regulator
Many folks and manufactures run LT truck tires on their trailers. (That is what Myco ships on their trailers that are not dually trailers?
Anyone have a rubber comparison on LT vs. ST tires?
Did rocket ever have any other names my sonic that i bought from kentucky is on a "fast load" and I had the rear axle snap last spring just wondering if there's any connection
