EcoBoost like expectancy
The EcoBoost are still relatively new so there aren't a whole lot of higher mileage EB out there. Will these motors last 150,000 miles without any major issues? It worries me a little bit that they are no longer offering the 100,000 powertrain warranty (at least to my knowledge). I will not be towing with this truck, I will be using this as a daily driver, regular trips to LOTO, and family trips to FL, etc. With three kidos, we need the room of the Screw so we don't have to take our Suburban everywhere. I think I will put 18,000 to 20,000 miles on the truck each year. I want a truck that I don't have to worry about once it gets closer to 100,000 miles and above. Would the 5.0 be a better option for my circumstances? It seems like the gas mileage is pretty close between the 5.0 and EB so there isn't much advantage there. I'm just wondering about the reliability of the EB given that it's relatively new.
Tough to say, ugly issues that are known the the majortiy of an engine group usually take a few years to show their face. High miliege over a short period of time is not always a good judge.
And the new 5.0l is not a proven platform either, it really doesn't have anything in common with the old 5.0l.
Drive them both, pick the one that you like, and then consider an extended warranty purchase as peace of mind.
We had to have new pistons and rings put in our Suburban with 50,000 miles on it. Chevy still hasn't worked the bugs out of the 5.3L with the Active Fuel Management. When it shuts down the 4 cylinders, oil from the 4 cylinders that are running slings oil into the inactive 4 cylinders which caused oil to get past the rings. We were using oil and had blue smoke out the tailpipe. Luckily it was covered under the 100,000 warranty. However, if it wasn't, I wouldn't have a good feeling if I had to fork over money to have this work done after spending all the money to buy the Suburban. I don't understand why Ford doesn't offer the 100,000 warranty like GM. It would give me a lot more comfort with the new motor.
In addition to the torture testing, remember Ford put a ecoboost truck through the Baja 1000 in like 38 hours full bore over that grueling terrain and weather changes, didn't skip a beat, impressive. And that engine in the Baja truck was the same one already used in Fords torture test that they swapped in, which shows even more how durable it was. If anything that and the Baja run combined would have shown flaws easily.
No engine is perfect, I'm sure some with higher miles will report some quirky weird issues that are rare like has happened with other reliable engines, but I personally wouldn't be worried. The engine had already been around before the F-150 got it.
Location: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
1 Post
I've got the EB in a Lincoln MKT. While I've only got 32K so far, I can't say one bad thing about it. I've been very impressed. Don't understand why Ford doesn't put this application in the Expedition / Navigator platforms.
