De-chroming chevy 2500
Just bought a 04 2500 chevy and was wondering if anyone has tried to remove after marked rock chip panels, fake chrome side mirror covers or door handle covers???
Yeah it's a bit of work but can be done send me an email
[email protected]
I took all the chrome off my gmc and made a Denali clone.
[email protected]
The door handle covers and mirror cover should just be double sided taped on. A little heat from a hair dryer or a heat gun should take those off. As far as the rocker panel covers are concerned they can be a pain to take off the same method could be used to heat them up and pull them off bu wear gloves since the metak gets hot. One thing that i have seen alot of is that people use that rocker trim to cover up damage so you may be in for a surprise once it is removed.
Anything w/ double sided tape you can remove w/ fishing line. Then to get off the residue use a 3M or similar eraser wheel, will be the only thing that takes it off without you hating life.
