New F350 or F450
Performance Boat Center
Go with the 450 if you're going to do the big tires/wheels.
I had a '12 350 and did the 2.5" spacer up front and a block 1' taller in the rear.
That truck towed great.
However I was not impressed with the brakes when they were really needed.. They were good at first, but pushing the pedal to the floor didn't help....
The truck pulled 18,000lbs fine, but I wound up leaving the stock wheels/tires on it because I didn't want to give up the performance.....
I'd say to do the 450..... and I believe the 450 has bigger brakes in addition to the bigger front axle.
The lower gear will let it pull the bigger tires...
If I remember the 450 was around $7k more than the 350.... I thought that was steep...
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim Gallagher
[email protected]
954-809-8739
i just got a 13 f350 with the 3.73, towed about 14k round trip about 500 miles last weekend,got right at 12 mpg, never had a concern about having more gear, pulled the boat out at the ramp at a 1000rpm's lots of low end torque, getting 19.2 mpg riding to and from town
