I HATE my DRW truck...
#34
Cat's eye is a great system. All you need to know is here http://www.stengelbros.com/LinkCatEyes.htm
Well worth a $160 bucks. Equalize tire psi and if one blowes or gets a leak it splits the two plus one easy valve to use.
#35
...2 times a year:
When I go to check tire pressures.
Getting to those inside rear tires is a BIOTCH. Last night was one of those 2X/year.
I do check my tires nearly every time I drive the truck though. I use the laser pyrometer (laser temp gun) to make sure tire temperatures are uniform at every stop; especially when towing. It works fantastic for such.
High temp = something is wrong. It's probably one of the best tools that I own. EVERY ONE of us should have one.
They make valve stem tube extenders that bring them to the outside wheel and mount there. They are easy to install and can be found at most truck accessory places. Just incase you wanted to go that route they take about 30 minutes to install!
