Whos towing larger boat with Lifted Truck???
I stand corrected. I didn't even catch that kicker dropping down to the hitch. Just a quick glimpse and I thought it was a type of ladder / torsion bar for the lift.
I'll toss it out there, that aluminum drop hitch will get some attention.
I
[ATTACH=CONFIG]529319[/ATTACH]
I like Stock ; )
I like Stock ; )
While I don't tow a big boat (27 fastech) I do tow it with a VERY lifted 7.3 F250. Its on 37's and 12" of lift. Like others have said, had to make a custom drop hitch (which you better overbuild, I bent the first one) to make it all work. The key is gearing and getting the powerband just right. My truck has 3.73's and needs 4.10's. Not a huge gear change at all, but just enough so it could hold overdrive better around 60-65ish. Mine also isn't turned up much, which also may make it better. Also, consider adding an aftermarket larger trans cooler, because lifted trucks put more strain (AKA heat) in the drivetrain and heat will kill an automatic transmission.
Charter Member#1545
