TRANSPORT NEEDED: 57' SeaRay. Florida to Texas
I`m looking for a transporter.
57 ft SeaRay. 14' wide. 38k lbs.
Merritt Island, Florida to Lake Texoma, Texas.
email - [email protected]
Text message: 940-632-9454
From BoatTest.com
Sea Ray 52 Sedan Bridge (Not in Production) Specifications
Length Overall 57'1'' / 17.4 m Dry Weight 40,267 lbs / 18,265 kg
Beam 15'3'' / 4.65 m Tested Weight N/A
Draft 51'' / 130 cm Fuel Cap 500 gal / 1,892 L
Deadrise/Transom 15 deg. Water Cap 140 gal / 530 L
Max Headroom N/A Bridge Clearance 20' 2''
We had our 39' mainship pulled from Fort Lauderdale to North of Houston. In our situation I'd still pull it again but the truck ride is harder on the boat then the water is. We had a busted out windshield and some other BS issues. Driver basically said to pound sand. Obviously you will need it on a truck to get it to Texoma but the less road miles the better in my opinion. Cool boat!
Settled. Let's put a OSO crew together and float it to Texas. You buy fuel, food and booze. We'll pick up the skanks on the way.
