Oil bath hubs on trailer
Any comments on oil bath hubs instead of grease? I have a friend that swears by them. It sure looks like a better set up if you don't lose the oil. I like the ability of having a visual inspection. Seems most of my issues in the past are from bad seals letting water in and doing the damage. Its a pain in the a$$ checking them all before each trip. Are some brands better than others?
I like the idea. But as you said, loose the oil and its going to be an issue quick. A few squirts from the grease gun and I know the bearings have at least some grease.
This article will give you some ideas of the pros and cons...
http://www.pacifictrailers.com/index...=553&typeID=91
Cheers,
Dave
Cheers,
Dave
Mine are oil bath but packed w grease. Go figure, i re did all the bearings and seals and added gear oil. I trailer a 42 everywhere and frequently. Prior to this myco i had posi lube axles w a zerk fitting on the end of the spindle which is drillled deep enough to shooot grease from rear bearing out towards the front bearing. All we did was pumped them before every trip and i mean every trip. Fill the void behind rubber plug w a couple squirts and u should have no troubles. Then there is no way water can displace the heavy grease. The only issue i had was rear seals rotted out from salt but thats it.
It's a awesome way to go. I was just thinking how much time it saves. I did mine on Saturday. Found 1 bad bearing set. And all my spring bushings were worn through. Just caught it in time. But changed all the bolts anyway. I wish I had oil bath hubs for sure. Maybe next year or next trailer. Next trailer will mean another boat
We have seen alot of them - like anything else - sealing important - condensation can be a problem in high humid climates. The oil needs to be changed in some cases more than what people think - most require straight 50 weight oil.
Not hard to change the oil in the hubs but most of the times the wheel has to come off. A very tiny funnel neck is needed to fill them back up to the recommended full spec.
these are the current set ups that alot of people are using. UFP products. I use to deal with them but they were bought out if I remember correctly
http://www.pacifictrailers.com/The-V...cation-System/
I have a number of customers who have them. I personally prefer grease. I check out our bearings each time we tow. If I had oil bath, I would have to drain and refill each time. Oil bath are OK, but not a replacement for regular maintenance and inspection of bearings.
