Hydrastar EOH Question
Old 09-15-2017, 11:58 AM
Sorry I can't get any pictures to up load but if you click on the link you can see a picture of the install
green lightning is offline
Old 09-15-2017, 12:31 PM
Originally Posted by green lightning
https://www.flickr.com/photos/154961414@N07/37243807925/in/dateposted-public/
I like it. Hope to get mine installed in the next few weeks.
shunter2005 is offline
Old 09-16-2017, 08:14 AM
F-2 Speedy's Avatar
Received 3,165 Likes on 1,409 Posts
Is the solenoid part of the break away system ?
F-2 Speedy is online now
Old 09-16-2017, 08:47 AM
No the back up solenoid is a extra add on , the break away system consists of the trigger switch and the battery to keep the pump running till the trailer stops moving
Old 09-16-2017, 12:21 PM
offshoredrillin's Avatar
Received 1,297 Likes on 449 Posts
thanks, one thing I found out last night was, the truck has to be running to energize the pump motor, F-250 integrated brake controller. I also thought it would easier to push the new fluid toward the reservoir.
just make sure the batteries for the break away unit are charged and pull the emergency pin and the motor will kick on then bleed brakes, furthest wheel first.
offshoredrillin is offline
Old 09-17-2017, 09:29 AM
F-2 Speedy's Avatar
my controller is trash, I can stop the fluid flow by putting my finger over the line, you cant do that if its putting out 1600 psi...........so I ordered this one, sealed unit unlike my current one.
DEXTER Electric / Hydraulic Disc Brake Actuator #K71-651-00 | eBay
Old 09-17-2017, 11:10 AM
DEXTER Electric / Hydraulic Disc Brake Actuator #K71-651-00 eBay
Just curious, what brand is your current actuator?
Old 09-17-2017, 12:52 PM
F-2 Speedy's Avatar
Titan brakerite, its not a sealed unit and has an exposed printed circuit board under the cover.
Titan BrakeRite Rite EHB Electric Hydraulic Brake Actuator Trailer Disc 1500 PSI | eBay
Old 09-17-2017, 02:18 PM
Titan BrakeRite Rite EHB Electric Hydraulic Brake Actuator Trailer Disc 1500 PSI eBay
One reason why I went with Hydrastar. Main reason to go with Hydrastar for me was the plug and play aspect. When I am able to get my coupler welded and my little wiring box built (to hide everything but the actuator) in the next few weeks, it will be nice to just plug everything in and go. No hard wiring and no worries about butt connectors and heat shrink tubing.
Old 09-23-2017, 03:18 PM
F-2 Speedy's Avatar
does the break away switch ( switch ground ) or battery ? plugged in the circuit is open, then pull it and closes and completes the circuit.
