Portable Air Compressor
Charter Member#568
I borrowed a craftsman brand one that plugs into the cigarette lighter. Took about half hour to inflate a tire. During that time it stopped working once due to overheating and needed to cool down. It also blew what i thought was a fuse in the truck so i switched it from the cigarette lighter to the power outlet to finish (or maybe vice versa). Despite checking every fuse in the truck I've never gotten that outlet to work again, don't know what it damaged. Worthless pos turned me off of anything that plugs into a cigarette lighter, I'd likely join aaa before bying one. Anyone know what to look for with my dead cig lighter/ power outlet on a 2003 Chevy?
Straight bottoms and flat decks
Forum Regulator
Charter Member#568
I've taken the dash apart to access the guages. A couple inches of wire is visible on the back of the outlet but I haven't done much more than check all the fuses and relays.
Charter Member#568
Wouldn't suprise me. It doesn't look or smell burned. Sooner or later I'll get around to checking rhe wiring at the socket and see if it's getting power. If not guess I'll be looking to join a Chevy truck forum to get to the bottom of it.
the socket and last few inches of wire burnout quite easily. Used to see it a lot on those trucks with guys plugging in rotator lights for plowing snow.
Forum Regulator
I just checked. It's the one closest to the steering wheel on my 2003 Silverado 2500HD that's shot.
I have a viair installed on my F250 with a 2 gallon tank. i have a normal 1/4" quick connect in the rear bumper and I carry a 50' hose with me. Plus I run the airbags, train horn, and air locker off it.
