DONE truck shopping...
Thanks a lot Brian......just when I had talked myself into being content with my 2010.![](https://www.offshoreonly.com/forums/images/icons/icon8.gif)
Nice looking ride. Looking forward to seeing it when you get finished with it.
Forum Regulator
For those of you that are waiting, and also the type that likes to modify the performance of your truck…
As you're probably aware the 2017 and up GM's have encrypted operating systems. This means there is no tuning and no DPF deletes, etc. etc.
Ford and FCA/Ram WILL do the same at some point in the near future. I can tell you for a fact that Cummins is deeply invested in this effort.
Just keep this in mind as you are debating your future truck purchases and long-term ownership. As soon as FoMoCo and FCA do the same, all of the leftover trucks will get snatched up quick since the market found out what this means with the 2017 GMs.
I'd expect the 2020 FCA/Ram trucks to be encrypted. And perhaps the same with the 2019 Fords come out; maybe a bit later.
Did you drive both transmissions? I have service cab chassis of each. The standard trans gear ratios are much better. My Aisin make a lot of noise (like a manhole cover being hit with a sledge hammer when it shifts in lower gears. Kick down when towing not as good as standard trans. It shudders bad before it kicks down. I have had all the updates done and have gone back to the 2nd update. Other than that. Great trucks. I love my 6" lifted 2500 HD Crew cab.
21 and 42 footers
Forum Regulator
I was very tempted to get a 2500 with the 68RFE; as I like the ride of the 2500 with it's 4-corner coil springs better. But here is what you give up if you get the 68RFE: Ram detunes the Cummins by 100 lb/ft. of Torque and 50HP if you get the 68RFE. They do that to "preserve" the transmission. YES, you can remove that torque/power management with a tuner, but there goes your warranty. I just couldn't handle leaving HP & Torque on the table, knowing my shlt is detuned.
I also drove this truck for a 30-minute test drive:
https://www.ebay.com/itm/2017-Ram-25...YAAOSwBRFaPVcT
...which is a brand new 2017 2500 Cummins/68RFE with 37" tires. The number one complaint I had with the truck is the transmission always seemed confused.
That dealer is the #2 in the nation, and has a FULL custom shop where they will build you whatever you want, (not tuned/deleted though), AND they will extend the FCA/Ram factory warranty over whatever they build. However, anything questionable would have to be serviced by them, which is 4 hours from home for me.
In the end, I went with the 3500 with the Aisin, because I did like the way the Aisin shifted and drove. I like that it is a stronger package. And even though the ride of the 3500 is rougher than the 2500, I have been in directly in contact with Carli Suspension's engineering team, and I will be installing one of their full bolt on suspension upgrades/lifts, (3"), which is actually 15% softer than the coil springs on the 2500. Yes, I will be installing airbags in the rear for towing, but I planned to anyhow, as the truck is getting onboard air/compressor & train horns anyhow.
Forum Regulator
The 1500 has that ridiculous rotating electronic gear selector on the dash.
The 2500/3500 Automatics have a column shifter, and in that same spot they have the rotating 4WD selector switch.
Pics:
https://images.auction123.com/f0119b....jpg?wtrmk10nw
![](https://images.auction123.com/f0119bbd-55ee-4d3a-bc1a-42fc8eaee310/3C63RRKL2JG111877/31.jpg?wtrmk10nw)
Congrats on the new truck. I'm sure you can't wait for it to get delivered. I'm glad to help you out in your quest. I would have been disappointed had I driven or flown a distance for that used one local to me. Going Ram with the Aisin tranny along with Carli upgrades will be a baddass hauler. About the only better suspension option for smoothness would be a full on Kelderman air setup. Eventually I want to go with Carli's leveling kit and Air Ride supplemental bags in the rear for hauling. Biggest tire I can go would be 35. 37s will keep me out of parking garages..lol Also, I'm willing to bet the 37s on the one you drove are what affected the transmission's behavior. Changing the height of the tires without any changes to the gears in the axle would confuse the computer. The speeds and RPMs would not match up. Might be why it was constantly searching for the right gear.
