trouble w/ the gm 10 speed in the truck line up >
Old 11-02-2024, 10:52 PM
Received 1,035 Likes on 520 Posts
Default trouble w/ the gm 10 speed in the truck line up
be careful w/ the 10 speed trans,,can momentarily lock up.
https://www.duramaxnews.com/post/mas...ecall-incoming
sutphen 30 is offline
Old 11-03-2024, 08:51 AM
Received 1,493 Likes on 833 Posts
Hmmmmm
I think that transmission is a joint design with Ford.
Wildman_grafix is offline
Old 11-03-2024, 09:06 AM
Yes, I have one in my F-150. But so far nothing from Ford regarding a TSB or recall...
Baja 252 Islander
bajaman is offline
Wildman_grafix (Yesterday)
Old 11-03-2024, 09:45 AM
I've got a 21 Sierra with the 3.0L DMax. Shifts hard in and out of 7th under load. This explains that apparently...
madflavors26 is offline
Old Yesterday, 03:24 AM
Seems the multi-speed auto trans in the perf diesel trucks are all having big issues. Often no parts available to repair.
The Ram auto trans is having issues in as little as 7500 miles.
Tartilla is offline
Old Yesterday, 12:14 PM
My 2020 Ford F-150 locked up in 7th gear just as I pulled into my garage. I called the local garage near me and he re-set all the codes with his scanner, and it started working properly again.
I called Ford, and they said to bring it in cause they had a bunch of software updates for it. I took it in, got it updated, and it has been great since. I do keep my local garage number on speed dial, just in case. Once stuff like this happens, I find it very hard to gain trust back in a vehicle, but I,m slowly gaining it, since it has worked flawlessly for the past 5 months.
350scarab is offline
