Towing advantage with 8 foot bed
I am getting ready to look for a new truck. I have made up my mind that it is going to be another f-250 crew cab with the camper package and stabalizer package. I will be towing a new 37 Chief that will weigh around 12k pounds with trailer and gear. I towed a similar boat with the same truck with the 7.3 liter and 8ft bed without any problems.
I would prefer the 6 3/4 bed as it is also my daily driver. Is there any real twoing advantage as far as stability with the longer bed?
Re: Towing advantage with 8 foot bed
No problem at all with the short bed, I used to pull the 37 with a Excursion 7.3, pulled great, just on the interstate if a semi flys by it will push the truck around a little, thats why I went to a dually. The new 6.0 is a much better motor than the 7.3. The trans in the tow/haul mode is great.
What power you going too put in the Chief?? Graphics????
James
James
Thunderdan:
This is interesting, in one thread they tell an OSO'er towing a 36 Nortech to get a dually. On this thread they telly you to go with the shorter bed. I would go with the longer bed with that much weight (12k).
Wannabe
Wannabe
Forum Regulator
I think having the shortbed dually will overcome the shorter wheelbase as opposed to having the full length of a full length bed. I have had friends who have had both, and stated this is the case.
As far as Fords go, I would want this order in means of towing stability;
Assuming all crew cabs:
350 6 foot bed SRW
350 8 foot bed SRW
350 6 foot bed DRW
350 8 foot bed DRW
Dan, Docmanrich37 has a 2500HD Chevy, CC, Short-bed, pulling his 37AT on a Myco with Electric over Hydraulic Brakes. I think you will be fine with whatever you choose, but if I were buying a Ford, isn't the F350 only a few hundred more than the F250?
PM Troutly for more info. He has forgotten more about Ford trucks than most of us will ever know.
350 6 foot bed SRW
350 8 foot bed SRW
350 6 foot bed DRW
350 8 foot bed DRW
350 6 foot bed SRW
350 8 foot bed SRW
350 6 foot bed DRW
350 8 foot bed DRW
350 6 foot bed SRW
350 8 foot bed SRW
350 6 foot bed DRW
350 8 foot bed DRW
It is not a $ issue for me, it is availability. I am looking at all SRW trucks. I did find one with the suspension upgrades so it has that, plus I anted the better ride of the 250. My last truck was a crew cab with the 8ft bed and it was a pain in the ass to drive around. I only tow maybe 4-6 times a year, maybe once down to Fla and back(I usually have it hauled). I was going to go with the shorter bed to make it easier for my daily driver.
But I also do not want to have an issue towing..
jamesd1
Superboat
3
04-01-2007 10:11 PM
Clay Washington
07-17-2003 09:43 PM
