Livorsi Monster Gauges >
Old 01-05-2008, 01:26 AM
Crazy Energy
Velocity Vector's Avatar
Pods
Velocity Vector is offline
Old 01-09-2008, 02:24 PM
Crazy Energy
Pod is fiberglassed and foam removed with acetone. On a test on the foam the resin ate the foam like acid so I covered the pod with a thin coat of elmers glue, let it dry before adding the resin and fiberglass.
Old 01-09-2008, 08:27 PM
Pat McPherson's Avatar
Looking Good.
Maybe Velocity will want to copy it...
Patrick
Pat McPherson is offline
Old 01-09-2008, 10:35 PM
Crazy Energy
I decided to go with a aluminum gauge panel. Would you paint it or polish it or cover it with vinyl?
Old 01-10-2008, 07:57 AM
I'd anodize the aluminum. I think you can get different colors.
Patrick
Old 01-10-2008, 09:55 PM
Crazy Energy
I got the aluminum panels cut out today and did some bondo and sanding need a little more and it will be ready for paint, I sent all the gauges I bought on e-bay to Livorsi and had the rims changed to polished stainless and have them all tested before the install. I will be using the mustard bezels to accent the stainless rims.
Old 01-23-2008, 12:40 AM
Crazy Energy
I have just a little more to go and this project will be over. I still have to cover the rocker switch panel and the tab / drive panel, I waited to show you the before and after. none of the panels are screwed in so everything is not exactly lined up yet, More later.
Before
After
I ended up covering the panels with a voilet purple carbon fiber look vinyl, The gauge faces are also black carbon fiber. I had Livorsi test the gauges and change the mustard gauge rims , the were bubbling for some reason, to polished stainless rims and used the mustard bezels.
Old 01-23-2008, 07:39 AM
Nice Work!
Patrick
Old 01-23-2008, 08:51 AM
Revelocity's Avatar
[I ended up covering the panels with a voilet purple carbon fiber look vinyl, I also had Livorsi test the gauges and change the mustard gauge rims to polished stainless rims and used the mustard bezels.
Where did you source the carbon fiber look vinyl from? I can see many applications for this material. Thanks.
Revelocity is online now
Old 01-23-2008, 09:04 AM
Absolutely tremendous!!!!
I love it. Awesome work. I am going to redo my gauge panel but I dont think I have as much talent as you. I too was thinking about using the corbon fiber vinyl look. I hope you can give me some advise after i start.
By the way are your old gauges still good? want to sell them? I may be interested.
Another thought I had was to cover my gauge panel with appliance epoxy(white)
Still kicking around Ideas but you just gave me some new thoughts.
Pete
drpete3 is offline
Quick Reply: Livorsi Monster Gauges
