Livorsi Monster Gauges >
Old 03-21-2008, 12:05 PM
  #31
Turned out awsome!!
DKerns is offline
Old 03-21-2008, 12:56 PM
  #32
1HYPER1's Avatar
That thing looks awsome,great job.
1HYPER1 is offline
Old 03-21-2008, 01:56 PM
  #33
Great job, looks like you need an engine syncro cause your idling a little higher on the left engine
Andy is offline
Old 03-21-2008, 02:57 PM
  #34
Crazy Energy
Velocity Vector's Avatar
Thanks guy's, Andy Ya, That's the side that has that big'O cam-ed 496. She lopes so bad it won't hardly idel so ya got to keep it reved up before you jam into gear so's it won't die coming out of the hole.
Velocity Vector is offline
Old 03-21-2008, 03:17 PM
  #35
Hey, Vec How Difficult Was It To Take That Whole Dash Assembly Off? I Am An Ex-bodyman And Am Pretty Competant... But Never Messed With Boat Disassembly
007joe is offline
Old 03-21-2008, 03:59 PM
  #36
Crazy Energy
I'm dumber than a box of rocks and it took me about 1.5 hrs. after screwing with the steering wheel. Hardest part was getting the dam steering wheel off.
Old 03-21-2008, 04:06 PM
  #37
On my boat the wiring is really tight behind that switch panel, I was having a hard time just removing that. If you dont mind answering, in what order did you remove the accesorys and the actual panel?
And by the way it came out sweet!!!
007joe is offline
Old 03-21-2008, 05:18 PM
  #38
Crazy Energy
Yes, it's tighter than a pig pu$$y. I started with the shift and throttles, Take it completly out. Then the trim tab indicator panel take it completly out, This will give you access to the main wiring harness, clip some wire ties to loosen up to harness to the speedo / tachs/oil/water. It's tight but will give you some room to work. If you want there is a quick disconnect plug in line with the harness but I didn't need to unhook it on mine after clipping some ties and if you do that you will have to clip most of the ties off. Then the switches, then fuel / volt / ignition / lanyards Panel.
Old 03-21-2008, 05:26 PM
  #39
That looks awesome.
JRalston is offline
Old 03-21-2008, 06:18 PM
  #40
Just noticed that you have room for 2 more gauges (boost)
Andy is offline
Quick Reply: Livorsi Monster Gauges
