Livorsi Monster Gauges
#45
Crazy Energy
1 Post
I started the dreded job of going back together with the Livorsi Mosnters. Today I cut the wood out for the relocated switches and the console installed. The fuel, volt, volt, ignition switches and lanyards panel wired and installed. 3 hrs. Going back together with the new gauges is a little more tedious because the old Graffig gauges has the lights pre-wired into the gauge and the Livorsi's have a light that has to be wired into the existing wiring that was on the Graffig gauges so I had to do a little extra work.
Joe here you can see how much slack I got after you get in there good.
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0001-1.jpg)
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0003.jpg)
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0002-2.jpg)
#47
Crazy Energy
1 Post
you are so FUNNY!! Hee! it's not that bad! Here's a marine color code chart
(BIA) Color Where Used
Black All Grounds
Black/Yellow Ignition kill circuit
Brown Alternator charge light
Pumps (bilge, live-well, etc.)
Reference Electrode - MerCathode
Brown/Orange Power feed to Auto-bilge switches
Orange Accessory common feed
Distribution Panel to Accessory switch
Anode Electrode - MerCathode
Orange Alternator Output to Ammeter
Lt. Blue/White Trim -"Up" Switch
Gray Tachometer Signal
Dark Gray Navigation Lights
Green/White Trim -"Down" Switch
Tan Water Temp. Sender to Gauge
Lt. Blue Oil Pressure Sender (10 Gauge)
Pink Fuel Gauge Sender to Gauge
Brown/White Trim Sender to Trim Gauge
Purple/White Trim -"Trailer" Switch
Red Unprotected Wires from Battery
Red/Purple Protected (Fused) Wires from Battery
Protected (+12V) to Trim Panel
Purple/Yellow Ballast Bypass
Purple (+12V) Ignition power feed from Switch
Instrument power feed
Yellow Bilge blowers
Alternator field to reg. field terminal
Starter Solenoid to Starter Motor
(MCM 470 and some Ford products)
Yellow/Red Starter Switch to Starter Solenoid
to Neutral Start switch
Tan/blue Warning system sense wire
(Audio warning)
Yellow/Black Neutral Safety switch
(transmission mounted)
White/Green Ignition module to Distributor
(Mercury Thunderbolt ignition)
White/Red Ignition module to Distributor
(Mercury Thunderbolt Ignition)
Dark Green Bonding Wires (earth ground)
Dark blue Cabin, courtesy, and instrument lights
Black All Grounds
(Audio warning)
#48
Crazy Energy
1 Post
I got the switches installed today, thank God I took plenty of pictures, what a rats nest. My fingers feel like they went thru a meat grinder. I just kept thinking about what 007joe said, "You are a brave man" and got'er done.
![](http://i265.photobucket.com/albums/ii230/velocity320/untitled-1.jpg)
#50
Crazy Energy
1 Post
Today I installed the water pressure, fuel pressure and oil temp gauges, these 6 gauges are the gauges my boat didn't have that I added. I had to make a wiring harness because there were no existing wires for them. I still have to run them to the engine sensors but I'll do that after the dash is finished.
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0005-5.jpg)
