260 prop question
260 prop question
hey guys i'm finally getting comfortable enough to run my boat in the upper end more often. i noticed now that i'm only getting 4400-4500 rpm out of the boat. it is a 375hp 496, its supposed to be good for 4800 i've. i'm running a 28"p 4 blade bravo, i was under the impression it was a 26"p. if i switched to a 26"p would this affect it the way i think? (extra 400 rpm and maybe a couple mph) also how would it affect midrange performance?
thanks in advance
thanks in advance
Crazy Energy
1 Post
thanks in advance
thanks in advance
Yes, do try a 26p and compare to the 28p.
A labbed 28p will likely be the fastest but you may like the overall performance of the stock 26p better.
Patrick
Patrick
Crazy Energy
1 Post
A 26 P is actually a 25P 4800 RPM 14% slip shows 65 MPH 12% slip is showing 67 MPH
Your 28P is actually a 27P so @ 4400 RPM and 12% slip you should be going 66 MPH now and 68 MPH @ 4500 RPM
I would call a blade co and get the 28 labbed instead of buying the 26.
another member may lend me a 26p (thanks in advance bill!)....... my 28 is supposed to be lab finished (by merc. i guess).... i've gotten 68.1 on the gps with my current setup and the tach was at 4400.... i think i'm going to try the 26 and see how it changes performance....
thanks vec.
by the way how do you calculate this stuff?
thanks vec.
Crazy Energy
1 Post
thanks vec.
thanks vec.
http://www.go-fast.com/Prop_Slip_Calculator.htm
If I can turn my 34P act a 33P @ 5800 and 12% slip I'm looking @ 106 MPH.
thanks vec.
thanks vec.
