Upgrading stereo
very nice.. I am curious to see how it finished up? gives me some ideas.. I have had mine for 6 years now.. so many different amps and such in and out it is time for a new one.. I do like open though.. plus a fan to keep things cool..
The sub woofer AMP (which is the only one that gets warm) has a built in fan. It is hidden behind the Silver trim piece. There is also a gap around the AMPs, that will allow the air the amp draws through the fan to circulate.
The JL amps I have do not have fans.. :-(.. but are supposed to be great class D amps.. might re-do my amp housing this fall.. just got done doing new gauges and more speakers this winter. and a rebuild on the drive as well as a p5 prop.. $$$ all spent..haha..
Amp Rack finished and ready to install. I was able to find matching vinyl. I padded it as well so it should look like it belongs there.... Do to space constraints I had to mount my sub amp upside down in order to run the wiring to it. Oh well.
How do you guys think it turned out?
![](http://site.activesportsunglasses.com/velocity/amprack4.jpg)
Here are a few pics of my "mock up" Sub Enclosure. It will be made from 3/4" MDF. I will coat the entire box inside and out with fiberglass resin and will vinyl wrap (as it will be seen when accessing the port-a-pottie. It will contain 1 Kicker L7 12" Sub.
![](http://site.activesportsunglasses.com/velocity/subbox1.jpg)
![](http://site.activesportsunglasses.com/velocity/subbox2.jpg)
![](http://site.activesportsunglasses.com/velocity/subbox3.jpg)
![](http://site.activesportsunglasses.com/velocity/subbox4.jpg)
Yes, I know my garage is a freaking mess!!!! And I have no idea why the floor under the bead is so dirty.....
is is dirty cause water can get in there is you have some in the boat and slow down fast i have found some in mine before. Your work looks great i ? why you want that much weight that for forward in the boat.
