30' Velocity Testing...
#41
Update...
Turned them in and gained 2 mph.
Motors are turning right around 5k, one slightly under and one slightly over. Had similar conditions, 1' to 2' chop, and 2 aboard, with a little more fuel.
Come on fall weather... I think some cooler temps and it'll push 80.
![](http://i215.photobucket.com/albums/cc120/ziemer99/JZ-79.jpg)
#42
Not a stupid question at all. Bravo pitch is overstated generally by 2". As I recall the explanation, Merc Bravo rates the MAXIMUM pitch (as it varies within the blade) compared to Hydro and most ever other prop is rated at the AVERAGE pitch.
#45
Labbing the 30's would be quicker then 28's and probably just as much as purchasing a pair would it not?
I sent BBlades a message and am waiting to hear. I don't want to weaken the props too much, if that's even possible, but I'd like to spin them like the 28's and drop my slip into the 5-8% range from the 11% it's currently at.
I used to drive at 3% slip with these drives and engines in an old chris craft and mirage plus'.
I can only wait and see what he says, maybe my goals are just unrealistic.
#46
![Smilie](/forums/images/smilies/smile.gif)
#47
I still have one motor tgat is lagging behind 200-300 rpm's so I think once I get that figured out it will definitely break 80.
Stay tuned.
![Wink](/forums/images/smilies/wink.gif)
#48
Couple things... Are your engines getting enough air? That engine cover looks pretty well sealed up. Most of the real fast ones have scoops / big air.
Also, can you give some specs on the small blocks? I'm planning a pair in the spring. Dart blocks, dart alum heads, air gaps, 10.5:1....
What exhaust do you have? Carbs? Especially cam. If this is too off topic, you can reply to my 30' redo thread.
Hoping the elusive 80 make is yours!
#49
#50
Been watching your posts/pics. This hull is a great design and a blast to drive. Good luck with your project!
