DANA LT500 Tabs/Trim Master Pump Oil
Anybody know what oil/fluid is used in the Trim Master Hyd. Pump that control my tabs (DANA LT500). Web search says Trimdraulic, but no longer made.
Trim Master is no longer in business according to prior OSO posts. Insta Trim builds a pretty similar performing pump which likely uses very similar fluid if not the same fluid. See: http://www.insta-trim.com/insta-trim...dable-oil.html
Quote from their web page:
TO BLEED
After complete installation, work tabs up and down a few times, then while in the UP position, remove filler-plug located on front of oil reservoir , allow trapped air to escape, insert plug. If unit should ever need refilling use Insta-Trim Biodegradable oil or any type of automatic transmission fluid.
