30' Steve Stepp Hual
I have a 1989 30' steve stepp hull and I am looking to see if someone can tell me if this hull is a cored haul. I am adding a in hull transducer but it will not work if it is cored Thanks
Bill
Bill
Last edited by rockycarr; 04-18-2016 at 07:16 PM. Reason: Corrected on wrong use of words.
If it has a cord, there is a LOT of wood in the boat,....... However if it has a core, particularly balsa and you cut and/or drill into it to mount a transducer, make sure you seal it good. When you think you have it sealed, seal some more.
It is no big deal, I had to do it my 1998 280. Use a appropriate size hole saw wit a short drill bit and remove the bit after the hole saw gets a good start. Seal it up good as stated elsewhere.
Padraig
Padraig
