VR 1 ready
24* deadrise, conventional lifting strakes with a 3" high notched transom. 1' wide pad. Pad is offset 6.5" to port of keel and 5.5" to starboard to offset the right hand turning prop.
The 290 is composed of balsa core hull laid up with general purpose resin, plywood stringers, bulkheads and transom. However, the deck is foam cored with vinylester resin.
They're the same in terms of dead rise and hull design. The difference between the 290 and VR1 are as follows. The VR1 is made up of coosa board stringers, bulkheads, and transom with vinylester resin throughout, foam core hull and deck.
Thanks,
Padraig
That is the online article from Boating magazine. I also remember a Powerboat/Hotboat mag stating the same. They must have been mistaken. I would take Kenny H's info as authority on the subject. My mistake!
if that was the case - one could have the outdrive dead straight and see the offset one side to the other of the pad position or least do the measurement
IMO that does not sound right for tracking - off center pad. I would also think that steering input and handling might be felt having an offset like that.
Back in the day we had a new boat with tracking issues and so forth, The transom assembly / drive was off center ---- a tad over an inch to the port side and the boat tracked poorly and leaned to Port. . V hull single engine with a big block.
Just posting so far on the research of the pad size and offset ---- I ended up talking to a buddy of mine whom has a bunch of powerboat & hotboat mags
Power boat mag feb 2002 with the VR1 on the front cover - complete story on the new Vr1 - not one word written about the pad size or offset.
Powerboat mag July 2001 interview with Step Stepp talks about the New Velocity F1 Racer not one word mentioned about any offset pad also in the same mag a brief story about the new Vr1 under News & Notes Leaks -- nothing mentioned about an offset or pad size
Powerboat Mag March 2004 -----Velocity 290 complete story about testing the 290 - not one word mentioned about the size of the pad or an offset.
