Cutting Edge Series II props
#51
Hey Diamond those look great! Are those the Max 5 copy from Cutting Edge?
Also I see you have the same top speed as a 28p bravo, but I'm assuming your RPMs went down?
#52
Offshoreonly Advertiser
Yes, Max 5 copy. RPM's stayed the same as the Bravo 1.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
#53
Good to hear. I'm going to purchase a 28p max 5 copy just like yours then. I'm building up a forged internals Whipple 496 for my stepped hull Nordic 28 Heat this winter and I think this prop will work.
#54
My 28P just arrived today. Eulises was great to work with on the sale. It will be a couple months before my engine is done and I can test it. The workmanship looks beautiful. Blades are definitely thin (Labbed).
#55
Update: I've run this new 15" 28P Cutting Edge 5 blade (pictured earlier) a couple times now with my newly built Whippled 496 (estimate 650HP or so) on my Nordic Heat. It handles great, much like the Max 5 I had on the boat before the engine build. It gets on plane without cavitation, no weird handling stuff happening. Ran at 5000 RPM at 75mph so it looks like around 15% slip (at 1,500' elevation). This is 1% slip greater than the 23P Max 5 had, but we're also talking a 230HP+ increase so hard to compare here apples to apples here. Overall I'm satisfied with it.
Next to test is a Hill Signature SL4 30p 4 blade. If that's too tall a pitch I'll try a 4 blade 28 either Bravo or Signature. My engine has the rev set at 5,700 so I can spin it up a little more if needed.
DiamondPerformance (11-25-2021)
